Zriuz wrote:could it be cause you guys have a massive turbo and a gizilion PSI.... N/A form its straight garbage, even tho i'm still positive the motor still have more than 200hp N/A to be had.
A the rod ration on the KA is not the best for RPM thus he want to De-stroke it. I'm not sure how much it will be to destroke the crank now days, but i'll just order longer rods and order custom piston with a higher pin, only if i was going for an N/A best.. since this is a turbo section de-stroking is futile.
Ok dude, you're out of your realm here. First off...this is the KAT forum. We discuss adding a turbo to everything. Wanna talk NA, go to the KA forum.
The head is straight trash you say. Well by all means explain why you think so. Besides your opinion, tell me EXACTLY why. Do you know what the flow numbers are? I'm going to guess no, because for a head that doesn't have variable cam timing it flows very good. What head in the Nissan world is better in NA form? I want technical reasons, not your deluded opinion BTW. Don't mention rpm either, since it has ZERO to do with the head flow numbers. I'm betting you don't actually have any idea what you're talking about.
Unless you can provide some type of answer to why you think the head doesn't flow well I don't want to see you posting in this thread. By answer I don't mean some diarhea of the mouth either, I want tech. I'll say good bye now, cause you don't have the answer.
WD
