480sx »
https://forums.nicoclub.com/480sx-u50548.html
Sun May 04, 2008 8:39 am
The stock ka has proven itself a few times in excess of 500 hp. It also has held 30 psi of boost for short amounts of time.
The Ka has a half weighted crankshaft. Due to this design, any rpm past about 5500 will cause bad crank harmonics and vibrations. These vibrations get exponentially worse as you continue up the tach. The vibrations leech power right out of your motor. In addition to that, the crank vibrations eat bearings alive, causing your motor to wear prematurely.
Im not saying that the KA cant make power up top, im saying its stupid/pointless to try to rev a stock Ka out past 7-7.5. With the way the engine is designed, you make your power between 3500-6500. That powerband is fine for putting down power. Hit 7k, shift, and let the low/mid range of the KA do what it was designed to do.
