koukiFC »
https://forums.nicoclub.com/koukifc-u92809.html
Sun Nov 08, 2009 12:04 pm
i ran 3in 5out on the same setup. ran my low throttle around -20%,bumped back 3 degrees timing,ran 10 psi,and 53-55 psi of fuel press(no wb so was playing as safe as i could). the hi throttle setup is user specific. theres plenty of info floating around. just takes time to sort through all the crap.
but to actually awnser you here is what i personally ran(not responsible IF you run it)
sr t25 at 10psi,n60(blow through setup),370cc,255 at 55 psi,3-4 degrees retard
lo thr= 1k-3k -20% 3k-7k -15%hi thr= 1k+10 add 2 each rpm point.
that setup is rich as hell but until you get a wb and a feel for the safc id rather run rich and change my oil all the time than lean out and blow up(been there)
Modified by koukiFC at 2:10 PM 11/8/2009
