1995240sxSE »
https://forums.nicoclub.com/1995240sxse-u36164.html
Sun Apr 29, 2007 7:39 pm
booo hooo hooo!!! I am ned sure what happend but I musta messed somthing up!!! Ok I now have a blown headgasket with out even getting it fired. I torqued it down like the manuals says. Also I have NO spark!!! When I hooked up my battery it arked very bad, I inmmediatly took off. No fuses were blown so I put back on, no ark. I figured what ever was done is blown/burnt. Turned key on to see what wasnt working, couldnt figure out what messed up. So I tried cranking. turned but not firing. Checked and was getting fuel and timing seemed right, but not getting ANY spark. I looked at my msd6btm's ground wire was not attached. So I thought that is why I got no spark. Grounded msd and cranked. No spark still. I am thinking that when It acked it blew up my msd cause it wasnt grounded! I was looking at btm Like, " I hate you msd!" I moved radiator hose and heard a noise. I squeezed it and water squirted out from the block and head. I turned my back on the car. I really took my time building this motor. Had some issues with the head. rebuilt a new one. bolted in on properly. then rused into throwing the motor in, I guess. Everything was checked except for the msd which I havent touched since it was installed 8 months ago, I guess I did for some reason unhook the msd. MAN WHY DID MY HEADGASKET BLOW??????? MAYBE FAULTY FROM FACTORY!!! I am thinking of removing the msd and running a straight dizzy! When a new headgasket goes in.
Would water squirt out of the area in between the block and head if head was warped a bit? I mean a steady squirt!
