Mikel wrote:As much as you can run without detonation. There isn't a set pressure limit, compared to the pressures of combustion, no amount of pressure a turbocharger can make will effect engine in any way.
AceInhole wrote:It's not an incorrect answer, but I'll have to disagree with that..... as running higher pressures will lead to more wear and tear on the motor (logically, as you have more pressure placed on everything from crank/ rod bearings to stress on the timing chain/ sprockets/ valvetrain). So... more boost = expect your engine to wear faster.
So, while running more boost may not lead to destroying the engine instantly, on a daily driver it should be considered that you're "kiling" the motor more and more as you increase boost pressures.
95_240sx wrote:Where does all your knowledge of KA's come from Mikel?
And you do have a good point, what AceInHole is saying is also true, and I dont understand where you linked your response and his response together...
Rick
KS_Honda_Killer wrote:Mikel, I also respectfully disagree. If your train of thought is correct, then as long as drag racers/nascar/indy/baja ect., just built thier motor to handle more hp then they motor produced, it would last just as long as a daily driver. This is just plain untrue. Some top fuel drag racers rebuild the motor every run. With increased hp (albeit from boost or compression) comes increased strain on the moving parts of the motor. The statement, "The actual pressure had nest to no effect on any of the rotating parts." couldn't be more untrue. Think about the way an internal combustion motor works. In it's basic form, it's just a complicated air pump. It gets it's energy from the expansion of the gasses during the power stroke. Now if we force air into the combustion chamber, we've already increased the amount of pressure in that chamber. Now if you measure the pressure created from an explosion in a NA vehicle and the pressure created from an explosion in that same vehicle under 7lbs of boost, the forced induction vehicle will create more pressure. If it didn't it wouldn't create more power. If nothing else, think of it like this, is it easier to squeeze a ballon with 1lb of air in it, or a ballon with 10lbs of air in it. If it harder to squeeze the balloon with more pressure in it then that ballon is exerting more pressure against you. More pressure equals more loading. More loading equals more stress. More stress equals more wear.
KS_Honda_Killer wrote:speaking of widebands, those would be for tuning use only, correct? I know a lot of ppl use EGT to measure their fuel ratios but I'd really like an accurate way to get real AF ratios invehicle. I know a wideband will run you close to a grand for everything, but does it last any longer than a regular O2 sensor? Just a thought I guess.....
Yes. With proper fueling, no detonation, I would see no problem in 20psi.AceInhole wrote:This is mainly the point I disagreed with. On a KA you can run a good 20psi on pump gas without detonation, but the pressures of combustion due to that 20psi (assume manifold pressure at close to constant temp vs. NA) will crack a ring or piston. You're saying that the original poster, as long as he has enough fuel, can run 20psi daily???
So you're saying that the stock rings and bearings won't be affected by more stress, exponentially greater than stock?? And that since there is no additional stress, a boosted motor will last just as long as the same motor running naturally aspirated. Those are bold statements, my friend.Mikel wrote:
Nope, saying that the same motor NA and boosted making the same amount of power will be equally reliable, actually, I would give the upper hand to the boosted motor, as it would be using smaller cams and less rpms.AceInhole wrote:So you're saying that the stock rings and bearings won't be affected by more stress, exponentially greater than stock?? And that since there is no additional stress, a boosted motor will last just as long as the same motor running naturally aspirated. Those are bold statements, my friend.
Then... it wouldn't be the same motor, would it....Mikel wrote:I would give the upper hand to the boosted motor, as it would be using smaller cams and less rpms.
In this case: same motor, same turbo, same intercooler, same fuel system. Yes. Higher boost pressures will lead to higher output. If he was already running at the limit of his turbo's efficiency, then no. It may not lead to higher output. Right now, he's supposedly running at a "safe" boost level. (9psi where his setup reportedly can handle 11-12).Mikel wrote:Higher boost pressure will not always lead to higher output.
Yup. It's a pet peeve of mine when people blame a setup having more power than another on one turbo being larger than the other.Mikel wrote:Whatever, we're essentially agreeing, and arguing semantics. It's just a pet peeve of mine to use boost pressure as a reference point.
AceInhole wrote:Yup. It's a pet peeve of mine when people blame a setup having more power than another on one turbo being larger than the other.
Thread jack :p
http://www.engr.uconn.edu/~corrales/240/
