AceInhole wrote:However, you can make up for a turbo's efficiency with a good intercooler. The intercooler's efficiency matters far more than the turbo's efficiency.
Ahh....no. The intercooler efficiency is important, but not nearly as important as the turbine efficiency. By pushing a turbo past it's window not only does it become a heat pump, but you'll spin the shaft far faster then its designed for. Which will lead to failure, plus your turbine wheel might unass itself.
The key to boosting the motor has been said like 25 times now. Eliminate detonation...I'm not saying you can run 25 psi on stock componants just cause your not suffering from preignition, but you can boost alot higher then then most people assume. 12 psi is not nearly the limit of the KA24.
I've destroyed a ton of RB20's do to overboosting and detonation. But once I added the proper amount of alcohol to the mixture and tamed the detonation, I was able to run 28 psi on stock internals, where as before I was killing motors at only 20 psi.
As far as regular wear to the engine is concerned, that is a silly argument. Of course your going to suffer from increased wear when you apply a greater force and any given object. It has nothing to do with CR or Boost. It has to do with the amount of pressure exerted on the object.
Hey Nils, if ya wanna run Alky/Methonal shoot me an email ro whatever. I've used it for the last couple of years. I'm surprised you never ran it on your GN.
WD
