KA-T POLL: Your WHP and your PSI
HIGHLIFE1
215 whp, 237 tq at 6 psi t04b
J
klattr1
Car: GT42R powered S14/KA
310 rwhp and 316 ft.lbs of torque at 17 psi on a t3/t04e. I could have advanced the base timing some and i also have had a knock sensor code the whole timing. Im not sure if its causing timing to be pulled out.Compression results of my 8.5:1 motor: 128, 130, 128, 128
turbotruck
wow those numbers from everyone look great... I took my hardbody to the dyno today and made a very depressing 157 @7psi to the wheels on a mustang dyno......I still have some spark and fuel issues but i will fix that, not bad though for a Bone stock KA with a turbo.. guess its time for a different intake and a cam :)
Projex240
Car: Dogs , My RIDE
jeez turbo truck--i made that on motor. You may hove some issues other than spark and fuel--maybe timing?
klattr1
i only made 178 rwhp at 7 psi on mustang dyno. When I dynoed on a dynojet at 7 psi, I made 201 rwhp. That a 11% difference.Mustang dyno's read lower compared to Dynojets but they are prolly more accurate.
turbotruck
Projex240 wrote:jeez turbo truck--i made that on motor. You may hove some issues other than spark and fuel--maybe timing?
The 240 had more power than the sohc motor so that is probably why, plus you probably have stuff done to your car too huh? My truck is bone stock other than a turbo, It would have only put down 90 to the wheels b4 the turbo, so thats a large improvement i think
den240
Car: 92 ca18det cnvt
On my 92 S13:
120hp @ 0 psi201hp @ 6.5psi (wastgate spring only)
All stock internals270cc injectorsstock ECUin-line 300zx fuel pumpFMUt3/t4stainless mani (now cracked at turbine flange weld)big FMIC (don't know brand)Pseudo-catalyticOEM cat-back
Should have some newer, better numbers soon with some upgrades...elec boost controller370cc injectorsSAFCIIApexi Dual-N15-speed instead of autolightened OEM flywheel
Red-KAT
Car: 1995 240sx-se ka24det
Base HP & TQ125 rwhp & 137 rwtq
Turbo is a TD06-20G188 rwhp & 204 rwtq at 7.3 to 8.0psi 9/1 afr
This is with no fan on the intercooler...
Modified by Red-KAT at 3:15 PM 2/15/2005
spindrift187
Anyone running a T25 off an SR?
klattr1
AceinHole is running a t25 from a SR.
nab911
Car: 93 Nissan 240SX SE
I want to know what dennis did different from you guys caus his 13 psi is raping you guys by a good 40 whp....
t66240
536.50 RWHP at 29psi....
Mike
klattr1
390 rwhp and 352 ft.lbs at 24 psi on built ka with Precision SC61.
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
t66240 wrote:536.50 RWHP at 29psi....
Mike
Umm…dyno sheet? Or the dyno shop number so I can call to verify this?
WDRacing
Don't Jack a STICKY....EVER. If your post was deleted, its cauyse it doesn't need to be here. This is a info thread only. If your panties got ruffled, email me [email protected]
WD
kaje36
213wrhp 226ftlbs5.9psiSMICSTOCK EXHAUSTT3 .45 with new houseings AR .60-compressor AR.63 turbine
I am changeing the houseings back to stock.. I think its giveing me alot more lag and a boost leak
I had detination a few days later,.. and we havent figured out why, Aceinhole was the one who tuned the car on the dyno ( first time It saw boost ) and it didnt spike when it finaly went ( I happened to be watching the gauge as a excelerated up an on ramp, and I never hurd detiantion...
t66240
kaje36 wrote:213wrhp 226ftlbs5.9psiSMICSTOCK EXHAUSTT3 .45 with new houseings AR .60-compressor AR.63 turbine
you really really need to get rid of your stock exhaust. It will give you power and spooll... the stock exhuast is very restrictive even for N/A
Mike
kaje36
t66240 wrote:you really really need to get rid of your stock exhaust. It will give you power and spooll... the stock exhuast is very restrictive even for N/A
Mike
ya I know, just dont have the money for one right now, and the DD isnt in production anymore. I am expecting half decent gains with the exhaust alone, but I got a few other things up my sleave that I think will end up happening before the exhaust. haveing the engine out of the car is nice ^_^ except for lack of transportation
I had alot of plans for my car before I went turbo.. and before I knew it I had all the parts I needed, and I didnt even spend much money
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Built and balanced KA24DE with 25G ... 402whp/392ftlbs at 16psi until boost spike caused the head to mushroom :D . I'll have dyno sheets in a few weeks after re-assembling everything ... sent the head out for cryo treatment; should help. Wastegate was sticking too; have to resolve that as well. Sheesh, I must be in contention for the world's most patient man.
95_240sx
Car: My baby (car)
435hp 391tq 22psi on 50/50 mix 93 and 110 octaneran out of spark at 22psi, and it was choppy there. Getting the head re-worked for more rpm's and better ignition. shooting to beat mike record of 535 :)
watch out buddy!
Rickhttp://www.ka-t.org
michael Walters
509rwhp @ 30psi
boost_boy
Quote »509rwhp @ 30psi[/quote] I can vouch for that.......
Dee
turbotruck
Any of these numbers with the KA24E, Or are they all with the KA24DE?
I am building a ka24e and i want to make some serious power!
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
There were some kae numers on page one, pretty impressive I might add. They were built though.
t66240
michael Walters wrote:509rwhp @ 30psi
what turbo you running?
boost_boy
He used a relatively small T04, but I'm sure he can answer this question better than I can.
Dee
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
:oy:
It's so nice to see people finding a use for the ole' KA rather then throwing it away. I was amazed at how much spunk my DE auto had compared with my old SOHC hatch...
Hey Dee what's the status on your next shipment of CA's?
boost_boy
Quote »Hey Dee what's the status on your next shipment of CA's?[/quote] They are here!
Dee
Nathan
326whp, 314ft. lbs of torque at 17psi, running 10:1 afr's, ignition cutting out, through a cat, and a good hot texas day. More to come very soon ;)
red240ne
Car: mmm...donuts
For now....201whp 268 ft lbs. @ 6psi1995 ka24de
T3/T04E 57 trim .63 a/r370cc injectorsSAFCCustom FMIC
going back to dyno in a couple of days...
