Couple things. For one, stop modifying your car if you don't know what you're doing. Oil is gravity drained...DUH. Sorry to be a prick but ffs dude I've been moderating this forum since 01 and I've never heard of anyone doing what you did.240sxRturbo wrote:ok so i bought this kit from cx raving not off ebay i accually went to cxracing.com and purchased it i am running stock everything im running 7 pounds on boost controller 38mm wastegaste and no my oil return line is acually dont make fun going to the valve cover (temporaraly) cuz i cant figure out what need to do to drop the pan
Don't make fun? We're not going to do that here.240sxRturbo wrote:ok so i bought this kit from cx raving not off ebay i accually went to cxracing.com and purchased it i am running stock everything im running 7 pounds on boost controller 38mm wastegaste and no my oil return line is acually dont make fun going to the valve cover (temporaraly) cuz i cant figure out what need to do to drop the pan
What's wrong with stock injectors and a stock MAF? Oh yeah, absolutely nothing.Ryencool wrote:Installing a oil return line isn't going to fix your problems. It explains the oil comming out of your exhaust, but your still going to kill your engine. Your not running any type of tune or engine management, piggy back, or stand alone. Your also running stock injectors, which is a no no. Then your running a stock maf, again a no no.
You need to unhook the turbo, and read some.
You should run a FMU with stock injectors/MAF so that you get more fuel in boost. To the OP, Google FMU and start reading. It stands for fuel management unit. It will give you more fuel based on vacuum lines.
You do NOT need any fancy electronics for 7lbs or less of boost, plain and simple. A few degrees retarded timing is also a very smart idea. And many people have run reliable turbo setups this way for literally longer then I've been alive.
zerothread/254009240sxRturbo wrote:how do i post a pic on here Ive tried figuring it out and cant lol
If your staying on stock injectors and MAF, you should not really go above 7PSI I think. I think that there are much more advanced people with FMU knowledge, but I think 8:1 - but I'm not sure.240sxRturbo wrote:what ratio fmu would i need for my setup at max i wanna run 10psi
