1sikS13 »
https://forums.nicoclub.com/1siks13-u47232.html
Mon Apr 06, 2009 4:41 pm
Its finally compete, and it runs like a raped ape. For the first time I have completed a problem with no problems. I just got it back from a friend who did all the aluminum welding and made my downpipe for me. Let me tell you, I am fully satisfied. THANKS KARL!!!!!!!!!!!!!!!Parts are as follows
T3 60 trim OBX turbo550cc side feed Injectorswalbro 255lph fuel pumpEBay top mount manifoldTial 38mm w/10psi springHKS SSQV (recirculated)JGS feed and drain line kitZ32 mafAEM widebandEnthalpy ECU from EnjukuMSD Blaster SS Coil10.4mm wiresFull 2.5 exhaust Open wastegate dump Centerforce DFX clutchB&M short throwFidanza FlywheelProsport oil pressure, water temp, volt, and boost gauges
manifold turbo and wastegate test fitted, i couldn't help itwastegate fitment was better then i thought it would be with the eBay maniintercooler mounted 32x10x3Karl did a sweet job on the intercooler piping, 1 piece hot and cold pipesblaster coil mounted upvery close fitment on the downpipe, still gotta make a heat shield. I was thinkin about earls fittings out of the master for the little bit of extra clearance, but i dont know yet, ideas are welcomeclean engine money shot
Overall for never owning a boosted car. It's very snappy and fun.
Oh and KA-T FTW
Modified by 1sikS13 at 7:55 PM 4/6/2009
