alta steve wrote:hey has the pvc pipe melted yet? just curious..
No it has'nt but that's probabley b/c I'm not boosting as yet. I've been driving with the wastegate off as I have yet to hit the dyno. Now a buddy of mine is using PVC tubing with his FMIC and he's doing ok at 7psi. As long as the conections are glued together it should'nt be a problem.
I'm sorry I have'nt been on for a while guys or updated things yet. I've just been really busy working. My wife is due with our second child in mid August so I am trying to work a lot to get a little extra money away.
I do have my SR injector's in now and my SAFC set to -27% currently. Everything seems to working just fine and I'll be doing my intercooler hopefully tomorrow. Then I can reattach the wastegate and boost just a little untill I hit the dyno.
Tx-Sx-FS wrote:hey, looking good, except the piping j/k. Well keep us updated and me about the fittings...i maninly need just the fittings for the turbo inlet and outlet..like most have flanges, does your use a flange?? Thanks. Oh yea..is that an S13 or S14? later.
Well for the turbo inlet I used the stock SR oil line coming from the turbo, screwed my restrictor to that then screwed my stainless line on. Then that line of course runs to my sending unit. The flange for the oil drain had to be custom made. The stock SR one was to small for our bigger motors. So a new flange was made and welded to a larger diameter tube for the oil to drain out properly. I hope that helps you a little. The best thing I can suggest is to take your turbo stuff to your local pro shop or hardware store and play with some fittings and find the right one that fits. Neither my installer or my self can find the reciepts that had the fitting names on them so for now, this is the best I can do. As for my car, it's a 1991 white hatch back.
iknowyoulike wrote:quick question...i'm doing mines soon as well i have everything as well..did you have to adjust timing too? or is the stock timing gonna be okay for a low boosting motor?
I have'nt touched my timing at all as I'll be leaving that to the pro's at the dyno. From what I've "heard", boosting with low psi with stock timing is ok but don't quote me on that.
MarkEmark wrote:What are the units on your fuel pressure gauge?!? Certainly not psi...
That looks like a gauge that'd be used on older carburetted engines, not modern fuel injected engines which run a LOT more fuel pressure, no?
And i would not trust that PVC piping for anything more than 4 psi or so...and I know this from personal experience. Luckily i was able to find out the blown intercooler pipe that fell off and skipped across the road into a ditch....
The MR gauge is just fine for any application. It's good up to 120psi of fuel and is just ment to assist my entire system and keep presure steady. I did'nt trust the stock fpr so I decided on this. I wanted to make sure that not one part of my entire turbo system was over worked. That way I'll get longivity out of it. As for the PVC, I answered that question above. I'm glad you had no damage from the pipe popping off.
I'll get a few more pic's up in the next week or so once my intercooler is in and I've done a little more work to my engine bay.
Thanks again everyone for your kind words and I hope I've helped you guys out with the answers I could give.
Take care.
