Tx-Sx-FS wrote:Hey, any updates man?? I bought the JGS kit for the T25, and a restrictor..but I dont have the right piece to link the restrictor into the lines and still hook upto the turbo..help me out man...thanks.
Well I never did hear back from my installer buddy so I'm gona try to see if I can explain my feed line in more detail. Now most of the fittings were bought at a Canadian Tire store in the automotive section. I'm sure if you go to a local NAPA or some other store you can get the same stuff.
Ok going from the feed line to the turbo here goes. The end of the SS feed line is male, a female/male connection attaches to it, then a female/male restrictor (not sure of the size but 1 1/16 sounds right), then a female/female compression fitting attaches to the restrictor. The 3/8's compression fitting is on the stock feed line on the turbo along with other part of the compression fitting that screws in to the female/female connection. Now at Canadian Tire there was a full 3/8's compression fitting set that had both of the connections and the comp fitting it's self so I'm sure a store by you would have the same thing.
As for the sending unit part, guys I'm sorry but I have no clue exactly what fittings were used. I know there's a fitting that screws in to the motor, then (I think) it's a British Standard fitting that attaches to that and the sending unit, then there's another fitting screwed to that and it attaches to the other end of the SS oil line. Oh, just make sure that for ALL these connections use either Teflon tape or some thread lock to ensure no oil will leak out and DO NOT over tighten the compression fitting (or any of the fittings for that matter) as you can crush them to the point that they will warp and thus, leak oil under pressure.
I'm not sure how much this is helping but I would suggest just taking your oil feed line and sending unit in to the store with you and start assembling it there so to speak. I REALLY wish I could give you guys exactly what fittings were used and so on but again, I never got the list that I mentioned earlier. If by some chance I do get it, I will post if for sure.
Hey Tx-Sx-FS, would you mind posting up all the pic's you saved on your computer of my install? I'm only talking about the ones I lost when the hosting site crashed. I would'nt mind having them back so if you could use the nico pic hosting and through them up, that would be sweet. I can then save them and keep them on my computer. Thanks brother.
Well take guys and let me know if there's anything else I can do. Hopefully I"ll also have dyno results to post up soon too.
Easy
