neverlift wrote: you thinking afc or rom, or both together are the cause?
This leads me to believe that you had a leak somewhere and it was causing you to run rich under no to minimal load. If you subtracted fuel from an area of the fuel map that was already lean enough, then that's where your problem lies.sunnys14 wrote: i subtracted a lil bit of fuel to compensate for the rich tune.
wow sig worthy at least.take it out of state on a flatbed if you need to, but next time get it tuned so that the afc isnt needed. Or tune it with a btm and afc like wd swears by but get it tuned this time by a person in person. did that make any sensesunnys14 wrote:no good shops here in sacramento. all i can do is trust enthalpy to tune for me. 2 s-chassis cars, 7 motors, over 35k in parts spent and im still here. cant leave now!
