sure if its tuned right lol IIRC holden is coming with a 10:1comp turbo motorsunnys14 wrote:is 9:1 compression low enough to even run 16psi on 91octane with t28?
wd is right though ,more than 10psi or so and the ka is just past a t2's breathability. 16 is looking for issues with heat, are you gonna use meth/water on that much boost? lol as well with stop blowing all the ka's I blew one so far due to a lying arse temp cluster gauge.WDRacing wrote:1 bar of boost plus T2 flanged turbo = stupid.
You guys running small turbo's need to look up exhaust reversion and the term...holy fvcking heat pump batman.
Blown pistons always equals a bad tune. They will easily hold 350rwhp all day with no knock.
Whatever you guys do, quit using up all the damn motors.
tell that to AceInhole. hes running a gt2871r .64 @ 14psi and he made 284whp and 340ft lbs tq. thats not stupid is it?.WDRacing wrote:1 bar of boost plus T2 flanged turbo = stupid.
i ran 2 top mount setups b4 with first being a t3/t4 57 trim .63 AR then a t04b 50 trim now a bottom mount gt28r. top mount setup had clearance issues on my car because it has ABS. i dont want to run a top mount anymore, so im trying to make the most power out of my existing turbo till i upgrade to a bigger turbo.neverlift wrote: thats just fine and dandy. But a t3/4 would have already made those numbers at say 10~11psi.... I run a t25 man calm down.
Mine (once IC is better new/fix current) will see 10psi daily and 12 for funtime, but I'll be adding something extra to the pot
I'm with ya on getting the most from what you have..... I will top out around 10~11psi with my t25, hope it makes 220ish(I'd love to see 240trq though) I finally leak tested my IC today and you bet it had a couple, boost finally stays above 5psi lol. Now its time to tune the piss out of it see if it make what I'm wanting..... Try to make a t3/4 fit on the bottom or make a manifold that clears... best of luck on the new old motorsunnys14 wrote:
