KA power steering pump on a s13 SR, Will it work?
jubee
Car: 92hs13
hey guys like topic says, just was woundering if it will work or not, would i need to do a little bit of modding or what. lmk if anyone has the answer.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
as long as its a pump from a DOHC car you will be fine, try searching next time, its been disscussed a few times.
jubee
Car: 92hs13
I did search only thing i saw was putting a ka PS pump on a RB. now do i have to use the SR pracket or can the ka bracket work as well. and if you have any links please post them up. cause i dam sure did not come up with anything.
thanks
austins240
Car: 93 240SX HB, 89 Rolla GTS
only the physical pump itself will work. you have to swap over all brackets from the SR pump and pulley.
Search again. there was a thread on this not one month ago. i posted in it too.
you + search = FAIL
Hijacker
Car: '92 240sx Convertible
'94 F-150
zerothread?id=263184
here you go jubee.
austins240
slik_s13
Car: 1990 nissan 240sx hatch back
i used a maxima psp, works fine. bolts up for the most part, i had to do a lil modifications but it was well worth the time.
