people allways bag on the KA..but in reality...normal damages for a KA series would spell new motor for say an RB or SR...just look at my latest thread about my massive damages..and it still ran...pics herehttp://www.myspace.com/lossoftractiondriftteamin the team dmg folder...triple r wrote:well after a well maintained 113,000 miles, my ka24de in my s13 started knocking today........looking to pull the thing out and take a look-see. knocks with no load at anything above 1500 rpm. dont knock under load........i believe i have had it. im in a toss up between either a ca or sr.......wanna keep it down to 4......i know ppl put rb's in them all day but im not looking for anything spectacular........just a little power to play
you must have the hook up then cause all ca18 i have seen have been cheaper than any sr20 ive seentriple r wrote:no.......i meant the timing set is good........and yea i have a buddy that had the ca18det... it is good, its just that i can find the sr cheaper
i beg to differ sire..thats a common noise when the upper guide is left on..the metal tab everyone takes off of there heads..we are talking about the timing chain guides upper and lower...the oem ones are made of plastic with a metal backing..when the plastic desinigrates...the chain will act like a saw shreading whats left of the guide till it breaks free and starts beating things up..like the tentioners....its allso..not uncommon for the parts of the guide to go shooting down the cover into the oilpan rite at the oil sump tube and bust that thing off..then that will allso move around and eventually get hit by sumpin moving like the crank or conrod end....he has to allso concider that there may be a tentioner failing too..and that knock he is hearing is actually his valves smacking the pistons couse he skipped a tooth...further investigation is requierd to find this issue...Philipio wrote:The issue is not with the timing chain guard. You would be hearing a marble in a tin can noise at idle and the noise would go away when you revved.
