K & N airfilters
Shadyg35
Car: 03 Maxima SE
Has anyone used it. I tried to insert it but it doesn't fit in my 03 SE. It seemed wider than the slot that it fit in.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
K&N's fit really tight. Did you buy part # 33-2031-2 ? That is the one for your car.
audtatious
I would also go with a dry hi-flow filter instead of a K&N.
Chris92SE
Car: 2017 Infiniti QX30
2003 Nissan Pathfinder LE
I have had the same one for quite a while in my QX4 (was in my older QX4 before) and it is a tight fit.
I guess you will just have to go get a cold air intake and a cone filter now.
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
i bought my injen intake about 2 years ago and the kit came with an "injen filter." so, i decided to be cheap and use the included filter during my install. later when i was getting ready and cleaning before a show one dayi decided to do anjd oil change and air filter change. i took the injen filter, which was by that time cover with caked-on dust, and tried to match up sizes with the k&n's. anyways to make the story short i had to buy a filter one size larger instead. i installed it and like it much much better than the injen filter! better throttle response, increased a little h.p. and sounded WAY better!!!
audtatious
Yes, I did the same thing. Wish I had a dry filter instead of the K&N tho.
Live n learn
MaximA32
I picked up an AEM Dryflow filter from my local parts store which is nearly unheard of because alot of the big chain stores dont carry that stuff. Just got lucky I guess. By the way, I love it. Sounds amazing.
AEM Dryflow FTW!!
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I could use some advice. I have a 96 I30 with 245k on it. I'm not ready to let her lose performance. I took out the stock air box which I've heard wasn't a great idea and replaced it with a ram air. I have no power during the warmer days here in Cali.
I see that there are CAIs for the Max but not the I30. I thought they were setup pretty much the same under the hood?
Also what's the concensus on gas mileage after installing the CAI?
audtatious
Maxima parts should fit the I30
For the most part, you get less gas mileage because you are more prone to put your foot down to hear the "roar"
Beancooker
There are only a few TRUE cold air intakes for the Max/I30. If it sucks air from the engine bay, it's a warm/hot air intake. Place racing made one, good luck in finding one. Cattman also makes one. $$$ You will also need to cut a hole from the engine bay to the inside of the drivers side fender. Those are the only TRUE CAI's that I've seen. All the others are WAI's
http://www.cattman.com/
audtatious
What's interesting is that the factory 2k2 intake actually ( tries to ) suck air from the front of the hood. In a way, it is actually a CAI. IMO. just a bit restrictive based on the design which is why a GAB works so much better.
Beancooker
Yeah, I wish I hadn't thrown out the intake piece (snorkel?). I would like to have that as well as my short ram. Kinda direct colder air towards the intake.
Sentientbydesign
96 I30 - Sold
Aren't there potential hazards in cutting a hole in your wheel well. Especially during the wet months? I've seen some sort of a breather. I guess that would help.
How about the WeaponR intake system with the hose and slot? My only problem is I don't see where I could mount the slot. I'd love to cut a scoop into my hood, but my wife will kill me and I'll still run into issues during the wet months.
Beancooker
Don't cut a hole in your hood. The Maxima is a nice car, don't disrespect her beauty like that. Plus it would look . Cutting a hole in her wheelwell is not a problem. The filter stays dry because of the splash guards. You can also buy a K&N drycharger sock to cover the filter. Unless you drive the car in water 12" deep you should be fine. Personally I won't use a K&N filter. AEM Dryflow is the way to go. Been using one for 10k miles and it's great. I would have done this if I had known more when I put on my intake. Hindsight is 20/20. If I keep my Max I will eventually do this, but I am looking at a 96 GT-R Skyline with 77k kilometers, completely unmolested (bone stock) for $18k. Gotta get Wife's permission first, and that's a hard sale!
MaximA32
AEM dryflow FTW. Good luck selling the wifey on the GT-R. I'm sure you'll need it.
Beancooker
Luck is an understatement, more like a miracle!!!
Sentientbydesign
96 I30 - Sold
There are splash guards in the wheel well??? Maybe I'm going crazy and don't know enough about my I, but I don't remember seeing any splash guards.
Does anyone have a picture of what a finished CAI looks like from the wheel well?
Btw how much was the AEM filter?
Beancooker
AEM filter, $45.+or- a few $$$.
Okay, imagine that the blue lines are the pipe and filter. (my art work sucks) If you look directly behind your foglight, in front of your tire, between the fender and inner wall of the engine bay, that's where it would go. Remove the plastic connectors around the wheel well. The plastic wheel well should remove. In that open aera is where the filter goes.
MaximA32
haha. picasso you are not noah. rofl
maxhopper
Car: 02 Maxima SE 6spd
NSR A32 wrote:haha. picasso you are not noah. rofl
Good representatation none the less.
MaximA32
true story. just saying itll never make it to the wall of the louvre. or mrs beancookers wall for that matter. haha
Sentientbydesign
96 I30 - Sold
Isn't that a 6th gen? I've got a 96. 4th gen. I might be mistaken, but I don't think we have the same room you guys have I've looked and looked and looked. Even to the point of pulling over in a McDonalds parking lot to open up my hood with a flashlight and contemplate where piping could go. It's really difficult with the limited space in our engine compartments.
Are there any CAIs for the 4th gens? And do they fit the same? Sorry I should just go search for threads on it.
Beancooker
My general manager drives a 4th gen, I'll look at his tomorrow and tell you what I see. BTW, I drive a 5th gen, and there's plenty o' room. That car is the only one I had good pics of that were both front and side.
MaximA32
Hows the GT-R discussion coming?
Beancooker
NSR A32 wrote:Hows the GT-R discussion coming?
Kinda like this:
She asked: "will you want to mod that car too?"I foolishly answered: "Of course!""So you want to get a car payment and the expect to spend more money on top of that?""That'd be cool""NO""But""NO, NO, and NO! Why don't you keep your Maxima and you can do whatever you want to it, within reason."When she said that, I couldn't argue. From this day on I have a $6k spending limit on my Max. $2k (give or take) per year.
Beancooker
Yes the filter will fit between the outer fender and splash guard in a 4th gen. I looked today. It'll be a tight fit, but it will fit.
Sentientbydesign
96 I30 - Sold
Finance a turbo for it? hahaha
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
I use K & N on my injen CAI. I love it. But a lot of people are not to fond of the red liquid that is in the filter. It can mess up a MAF and ect. What i do i have two filters and let one dry out after i clean it and reoil it as i'm using the other. If u let the K & N sit for awhile you can see oil drain out to the bottom of the box.
GarageToys
Car: 2001 I-30T
Why is the dryflow filter better than a K&N? I'm not defending my K&N, just wondering.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
K&N uses oil which can cause problems with the MAF. Dryflow doesn't use the oil, so you don't risk the MAF issues.
