koukiKA240 »
https://forums.nicoclub.com/koukika240-u16651.html
Tue Oct 19, 2004 1:00 pm
Its running rich. The smoke is Black, it smells rich. The motor has a brand new nissan crann, pauter connecting rods. CP 9.1:1 forged pistons and the bottom end has been completely balanced.
The head has JWT cams, JWT springs/retainers and JWT timing sprockets. All Grounds are clean.
As far as the Throttle Position Sensor, im not sure. It does recignize my throttle position as 0.0% when closed and 100% when open and everything in between is correct.
I do believe the IN/Out settings are wrong. The car is outta my hands now and im in school so i cant make the hr and a half drive to the shop to test out the 1/6 setting.
I spoke to the shop today. They tell me that they can get the car to run right off of the SAFC and get me down the road.BUT they informme that with the MSD 50# injectors the Walbro Fuel pump and Z32 MAF it is too much for the SAFC to handle efficiently. They tell me that because ive gone in and built the engine and have all the extra fuel delivery i can have a more streetable higher HP engine with the JWT ECU.
They want $550 to send the ecu to Jim Wolf.Is that price good?What are your thoughts on their final diagnosis?
They promise it will run great with the new ECU. They are a trusted shop here in houston and have been around for a long time.
P.S. as far as the timing. The dist is set correct and the timing is at stock (20degrees plus)Thanks for all the help,~Sam
