just ran an 18.229 in the quarter
RobDET
Car: Cars
AZ ment shorter sidewall not skinnier... 215 is the width it's the second number he's saying to reduce... like 215/50R 14's would significantly reduce your gearing...
The KA rearend won't fit cause the truck isn't IRS
The KA transmission is the same in the truck and the 240. The housing is only slightly longer in one... Gears are the same...
Mr1der
what's the ratio on the rear end of the truck, I'd assume it's lower, and can the 240sx ring and pinion be used on it?
I forgot about IRS...DO'H
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
Good question, who would swap the entire rear end when you can get just the ring and pinion in 4.36 and 4.63 ratios from Nissan Motorsports?
But, is it a direct swap?...I don't know s*** about the trucks.
RobDET
Car: Cars
If anything i would thing the truck would be geared numerically higher than the car for increased towing capacity... I don't know the rear end numbers for either tho...
Stoneage_Turbo
Car: 1994 Caddy Deville 4.9
Just about anything
i think a pratt and whitney jp-85 strapped in the bed of that thing might help it make a 15 sec 1/4 mi
Mr1der
hell freakin yeah!!!
I H8 UR DSM
jhoward
Car: design, cars, music
i need some help here guys. just very cheap ways to go fast.
cnichols
99 Infiniti Q45
93 Ford Fastiva
Cheap and Fast shouldn't be used in the same sentence....sorry. Nitrous is the easiest way to go fast, but if that's your only mode of transportation....not the best plan.
RobDET
Car: Cars
GREAT avatar cnichols
jhoward
thanks to all who helped me figure out that i'm just going to wait. i'll just save up so i can make my truck killer by dumping a lot of money in it on good stuff. thanks again.
Mr1der
dude, you should put an RB in it, that'd be really scary....
Nismo_Freak
Car: 89 Nissan 240SX
RB20, good sound, good power, and good reliability.
You can pick them up for pretty cheap too.
cnichols
99 Infiniti Q45
93 Ford Fastiva
RobDET wrote:GREAT avatar cnichols
HAHA, I agree! :D
I just wish I would have come up with it myself. I'm actually amazed I didn't as much as I make fun of "Blingsters"....what I call people who like to Bling it up. It's so ridiculous, but so much fun to rag on them.
