LiU wrote:1) what are some reputable places to get CAs? Or rather, where do most of the CA folks get their motors?
I'd say the majority of people have gone through venus...but a big problem with CA's is that there aren't many places to order from, and the ones you can order from (like Venus) have quality issues...
LiU wrote:2) the CA motors are older and how much maintenance do they need (in terms of $) once I get the motor?
Expect to put in new main bearings, rod bearings, and all engine gaskets. Luckily parts from the CA18DE pulsar motor are completely interchangable so just order a gasket set from Nissan, and you'll be set! (also check the crossover parts sticky)
LiU wrote:3) what kind of mounts should I use forCA -> s14 240sx
the same mounts you'd use to put an s13 SR into an S14... I don't have an s14, but its exactly the same process as putting an s13 SR in!(but the wiring is 10x easier!)
good luck and make sure to search the archives...there's a ton of CA info here (I'd say we have some of the best CA info anywhere in the archives:D) so make use of it!
Sean
