Can you post some pics recently looked into springs and all the pictures don't work since photobucket changed their forum policy.
Nice. Glad you like the ride and height. The pic isn’t coming through on here. Ive decided to forgo coilovers and wheels and keep the car as is. Still looks great and sporty. The lack of aftermarket stuff for our cars has killed my mod bug. I’m currently in the process of modding my Yukon instead.
Thanks for the pics looks awesome
Here's mine lowered on Eibach springs, I tired the BC coil-overs but I could not get the driving comfort with how low I had it. (Trust me I tried everything) I drive about 30k a year so I went to Eibach, they measure 28-1/4" Front and 28.0" Rear. Just added these inexpensive wheels and I am having R-1 cross drilled / slotted black rotors installed this Friday.
Thanks for the input. So did you need any kits other than the lowering springs to adjust your specs?RL15Q70S wrote: ↑Mon Feb 12, 2018 1:14 amHere's mine lowered on Eibach springs, I tired the BC coil-overs but I could not get the driving comfort with how low I had it. (Trust me I tried everything) I drive about 30k a year so I went to Eibach, they measure 28-1/4" Front and 28.0" Rear. Just added these inexpensive wheels and I am having R-1 cross drilled / slotted black rotors installed this Friday.
LeRoy712 wrote: ↑Thu Sep 29, 2016 2:10 pmI'm at 28" in the rear and 28.5" in the front.RL15Q70S wrote:Leroy712 - Looks really good! I have the same car and wanted to know if you could send measurements from the ground (center of wheel) to the beginning of the top fender lip front and rear? I think you should be around 29"... Just want to know where it sits vs. the Eibach kit.
So if I'm reading this correctly the RS-R Down Spring Set item N281D for the RWD M37/M56/Q70 Fuga Y51, could be stiffer up front and the same in the rear. This leads me to believe the RS-R front springs would be suited for the V8's possibly?
C6Joe1957 wrote: ↑Sun Feb 14, 2021 9:30 amSo if I'm reading this correctly the RS-R Down Spring Set item N281D for the RWD M37/M56/Q70 Fuga Y51, could be stiffer up front and the same in the rear. This leads me to believe the RS-R front springs would be suited for the V8's possibly?
Available here: https://www.amazon.com/RS-R-N281D-Sprin ... B00A9PKKJ2
If it helps you out, OE's and aftermarket spring manufacturers almost universally try to match front and rear rates to the vehicle's F/R balance. Putting higher or lower rates than the weight balance demands at one end-only tends to make for weird response to bumps and skittish handling in general. The only good reason I can think of to deliberately mismatch them is if you spend your life making donuts. But the upshot is, if you buy a matched set from the same manufacturer, they'll definitely have made efforts to match the ends to the application.
