Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Dec 24, 2006 2:29 pm
Since modded ecu software leans the wide open throttle A/F ratio and advances the amount of ignition advance vs STOCK PROGRAM,.........if a stock program has its CAS misadjusted towards 17-18 degrees and has dirty injectors, low fuel pressure, or a funky MAF.........it is possibble to randomly create some or almost [no redline or speed limiter] increase all of the improvements of the ecu reprogram.
If the fuel pressure never went above 34 psi [to normal 43.4] the A/F ratio would be leaner by 11-12%...........acceleration would suffer up to 3400 rpm but the dyno would show an increase in power to redline after that.
