elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun May 28, 2006 12:59 pm
FRIDAY PRE MEET INFORMATION CHANGED, PLEASE SEE FIRST POST TO REFLECT CHANGES
The tech will be done Friday starting at 3:00 PM, at MUNCIE DRAGWAY!!!(20 minutes away from the Anderson-Darlington airport) I got the track for us, and only us from 3-6PM to do some "heads-up" drags. Each car will get their 3 passes, and each car will get their 0-60 MPH times also!!! I really appreciate Roger at Muncie Dragway for helping us out on this with such short notice. They are also prepping the track for us. (Guess the burn-outs are OK now!)
The tech will be done there. If you want to stay and race (AFTER we get your times for this event), you can, or you can just stay and watch some great drag-racing action!!
If you are not able to make it at that time,(3-6) we can get you in for your times during Saturdays events at the strip, OR squeeze you thru friday evening. They are there LATE on Friday. You have different options to do, but we can get you thru.
Then Saturday, its business as usual on the tarmac at Anderson-Darlington airport. (Huge autox, Skidpad, and HUGE car show)
The tires you use at the strip, ARE THE SAME YOU USE SATURDAY!!!
