Personally, I would probably be comfortable between the ranges of +35 to +45. I don't know if it's because the Juke is a smaller car, but a +47 offset would make the tire go further into the wheel well and might rub.
I prefer the tire going out more if anything on the Rogue.
You can check online on those wheel calculators and figure it out that way too. I too been trying to find the right wheel but its a pain in the a** trying to find something I like. Little did I know that all the wheels I want are usually not close to the +40 offset and to top that off try to find a wheel with a center bore of 66.1 on rims that you might like. Don't get me going on spacers and hub centric rings, which I prefer not to use if possible but THAN you would not be able to get any wheel out there that you might like.
It's like we are not suppose to find wheels that we like in this world to fit our Rogue. As they say, the Rogue is the least customizable car out there it seems. Yah we could do a little mod here and there, but in the end its like. Hey, there's a Rogue, that looks like my Rogue, that looks like his Rogue. You know what I mean. For example, google a Nissan Rogue and all of them look the same.
Sometimes I just stare at my Rogue and the more I look at the wheels, I think they don't look TOO bad. They are not flashy yet not dull either. Kinda perfect I guess. I found them easy to clean too for some reason which is good.
Moreover, it's kinda unique since they changed the wheels for 2011. If I ever get new wheels, I probably have to get some hubcentric rings.
