My experience with a 2009 Rogue S with factory steel wheels - I put used 2014 Juke 17" wheels from eBay and they work great.
Old: 16" x 6.5" x 40mm offset Steel wheels with 215/70/16 tires
New: 17" x 7" x 47mm offset 2014 Juke wheels with 225/60/17 tires
it looks like the Rogue S does not have a 17" factory option but the SL does and it is 17" x 7" x 40mm so it can take 235/60/17 tires without any issues. However, putting the 47mm offset Juke wheels on a S model rogue, the front wheels (not the back) the 7mm the wheel goes into the well, you lose that 7mm so if you put 235 tires, you have a high risk of scraping the plastic lip of the suspension that juts into the wheel well (I don't think that is a big deal, though). 225 tires still fit OK with enough wiggle room even with the 47mm offset tires. Take a look at
http://www.wheel-size.com/calc/?wheel1= ... m&scl=50mm for some pictures on fit.
A colleague told me that the 235 tires are made with compounds that have a higher coefficient of static friction than 215s or 225s so you get better traction at a slight loss of fuel economy but this consumer reports article paints a different picture
http://www.consumerreports.org/cro/2012 ... /index.htm
The link you had says they have an offset of 48mm. There are others that claim that 2014 Juke wheels have an offset of 40 or 42. I certainly got confused. I got the used ones that I thought were 42 but ended up being 47. Have the seller send you a pic of the back to make sure of the offset (see the photo attached) and then calculate from there. If they are 42, you can get the 235mm tires
image hosting no registration
