Exar-Kun wrote:try running a 245-40-17 and a 255-40-17. that'd be much better suited to those wheels.def- s14's have about .5"-1" more clearance than s13's do.235-40-17's will be super stretched on a 10" wheel, I dont reccomend it.
if your going to run the 235's run those up front and a 255 in the back, but the 245/255 f/r setup would work lots better(and allow the tire to do its job better by matching the wheeld with)-chet
Let me clarify... I made a thread on FA just to get the opinion of the regulars over there(and to add to my 2 post count... heh), and the consensus was that a 17x9" wheel will NOT fit the front of an S13 with anything wider than a 215 tire. Which is obviously not optimal to say the least.
I'm more interested in running a 17x9" frt and 17x10" rear setup. I'm thinking either 225/45-17's up front(too narrow IMO, although they are "wide" Kumho MXs) or 245/40-17's(preferred) on the 17x9"s. I was basically told that even with a wide fender to give maybe 1.5" more clearance and proper offset, that I would have to TUB the front wheelwells. I was never really told why I would have to do this, but I assume it would have to be due to rubbing under steering lock? +15 offset and rolled fenders or wider fenders should put the wheel far enough away from the coilover.
Rears I'm looking at either 255/40-17's or 275/40-17's on the 17x10" wheels and rolled fenders. +25 offset should do just fine.
So is my front setup feasible on the 17x9" wide wheels on an S13? I will curse a great deal and mold up some wider fenders up front if that's necessary, which it seems like it may be.
I don't want to go with a greater than 1 inch stagger, as I only forsee a max of 350ish rwhp, and it might actually be less than that. The car will definitely be front heavy after I strip it too. If this setup doesn't work, I'll go with the tried and true 17x8 up front and 17x9 out back. That's still alot of tire, but I'm building this car to excess and it won't really cost me much if any extra to go 1 inch wider all around if things fit like I think they will.
This car is destined to be a supercar killer(or at least P-Car humiliator:)) on the track when I get my skill level up to the same awesomeness I hope to build the car to, so these tires sizes are absolutely not out of the question or too large. Heck, I kill 245/40-17's in no time due to heat in my 3150lb M3, and the average supercar weighs about the same as a stripped 240SX and has WAY wider tires.
Sorry to hijack the thread, but I don't quite think it's worth of a new topic.
