joined the fn01r-c club
Dori Dori
Car: Cars of course
Def wrote:Does anyone have a reasonable idea of what is required to fit some 17x9" wheels and 245/40-17 tires up front on an S13 though? I guess I'm getting so many conflicting reports I'm just going to have to buy them then make them work and report back here. Oh well - might as well do something new in the Nissan community right off the bat. :)
S14 LCA's...you'll then have the same clearance as an S14.
BuudWeizErr
fish: i have 5 lugdoridori: LCA's won't give you clearance. Only thing an S14 LCA on S13 will do is push the hub outward allowing you to run a higher offset wheel and having it be as flush as a lower offset wheel without a spacer.def: i've HEARD but have not checked the truth... that you can't fit anything more than 215/45/17 on a 9 inch wheel up front. I'm going to try for 225's, so we'll see.
Def
Car: Cars, Engineering Stuffs
But wouldn't moving the wheel out a bit and running a wider fender make this possible?
What with tubbing the wheel wells for such a minor increase in tire width? I never got a straight response on FA, and honestly, I questioned whether some of the people giving advice knew what they were talking about(i.e. swore up and down that a 10" wide wheel WILL NOT EVER fit under heavily rolled S13 rear fenders, bah - stock fenders give you 10.5-11" of clearance.)
shift_sr
alright guys I have one to spit at ya. I have a 93 240 w 5 lug swap i wanna run 17x8 front and 17x9 rear FN01R-C but what offset would i be lookin at and what size tire do i wanna be running. I know this has been discussed millions of times but I can't get a straight answer. HELP ME PLEASE!!!!
Dori Dori
Car: Cars of course
ChunkiDori wrote:fish: i have 5 lugdoridori: LCA's won't give you clearance. Only thing an S14 LCA on S13 will do is push the hub outward allowing you to run a higher offset wheel and having it be as flush as a lower offset wheel without a spacer.def: i've HEARD but have not checked the truth... that you can't fit anything more than 215/45/17 on a 9 inch wheel up front. I'm going to try for 225's, so we'll see.
I was talking about coilover clearance...if running a 9" front w/ a 245 series tire, there will probably be a coilover clearance issue. Def got it...
Dori Dori
Car: Cars of course
shift_sr wrote:alright guys I have one to spit at ya. I have a 93 240 w 5 lug swap i wanna run 17x8 front and 17x9 rear FN01R-C but what offset would i be lookin at and what size tire do i wanna be running. I know this has been discussed millions of times but I can't get a straight answer. HELP ME PLEASE!!!!
215/45/17 front, 235/45/17 rear.
17x8 should be +25 and the 17x9 should be +35.
chmercer
lowest offset they make and flare fenders
BuudWeizErr
I talked with one of my friends about tire clearance up front. he has seen 225's up front and 235/40's on stock s13 fenders. so there you go. even 9.5" +12 wheel fits with stretched tire.
shift_sr
would a +27 be alright instead of a +25 or is there no play in this?
Def
2mm is a gnat's *** in relative terms. The choice of tire makes more of a difference than that really.
I'd say you'll be fine, as 17x8" +25 isn't really hugging it really close up front. If it is a bit close, all you have to do is get a 5mm spacer though, so it's not a show stopper if by chance you do get rubbing(but I doubt it).
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
I've thought about getting rid of mine and getting some more with differnet offsets, but mine are pretty good the way they are now. 17x8's all around with +35 up front and +25 out back. If I do get rid of them, I am getting hyperblack and changing my widths/offsets.
Nice choices everyone.
