JiffyLube effectiveness
Altiman94
Car: 1989 Nissan 240SX
If an engine is really that sludged up I would pull apart the engine and clean it myself. While it is apart is a good time to replace all the parts needed for a full engine rebuild. Killing 2 birds with one stone in this case.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Thats not that bad of an idea..... However, I might disagree unless you have a lot of time...
I guess if everything else isnt worn, might as well.....
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
no way to relaibly rebuild a Q45 engine DIY unless one has say $500K in machine tools etc. to work with like a Formula 1 engine shop.
Dropping the pan, doing the timing chains OK. Valve job-?? Send the heads to Faerman Racing in Houston (or equivalent) who routinely do 5 angle valve jobs as well as special work for racing folks.
Rex Rich
Car: 1991 Q45
Jiffy Lube, Home Depot, Mc Donalds?
