Jgy fuel rail and injector fitment issues into intake, help
tay-fu300zxtt
Car: 300zxtt,
well after family issues and new house being finished ive made some changes to my ride . I have run into a issue. I have 14mm 1000cc domestic fuel injectors that don't fit deep into the intake like the stock ones Did. The domestic ones have a lip on the bottom, and looks like they would not seal or operate properly. Any ideas? should i just machine the intake??? I'll post pics in a sec.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Are you sure that 14mm injectors fit in the intake manifold?
And how is the fitment between the injector and fuel rail itself? Does everything seem to clear (plug, o-ring, etc.)?
<edit> After a simple search for "14mm injector", I found this thread that has your answers including good pictures. Try that next time first...
zerothread?id=249157
Modified by Darius at 1:27 PM 4/15/2009
tay-fu300zxtt
Car: 300zxtt,
fits great in rail. The lip of the injector seem to be stoping the injector from going in the hole. Its like if i machine the lip off the injector or machine the intake the injector would fit. I was not sure if it was something..
tay-fu300zxtt
Car: 300zxtt,
Darius wrote:Are you sure that 14mm injectors fit in the intake manifold?
I searched that already , he says his issue was the injector going to far in the fuel rail. Mine came with the clip hes talking about.. thanks. I used the stock seals ..This lip of the injector seem to be stoping the injector from going in the hole.
Darius
What kind of injectors are they? Bosch? Denso?
tay-fu300zxtt
Car: 300zxtt,
DOMESTIC STYLE looks to be bosch
Bluefire
Stock intake manifold is not meant for bosch style injectors. I'm not sure you could even machine the stock manifold to fit those injectors.
