man i thought i was special, got the same clock as well as a president airbag.
accessories are cool and all but i need the front end/trunk conversion.
i've done a ton of led work for various cars. so far all i've done for the g50 ('90) is replacing type 74 bulbs with spares i had as i was working on stuff. the clock, key ring, and ashtray are all 74 in twist lock bases.
*edit- just realized the op said the clock housing had to be swapped out, so 74 might not work in the us spec.
