Ok everyone i have recently installed the JDM DCC. I have run into a few problems im hoping that someone will be able to help clarify. First problem of which is the lights when i turn on the daytime running lights and headlights the DCC unit goes very dim, and when i try to make them brighter with the dimmer nothing happens. i am not to sure what wires are for the lights on the dcc if anyone knows please let me know. Now the second problem is the outside ambient temperature sensor i also need to know the wire colors for it. I have all other sensors and motors hooked up unfortunately the outside temp sensor was cut. I am almost positive that the 6 pin JDM connector is where the sensor needs to plug in but i only need to splice 2 wires in, so just need to know what colors they are. Also need to know if its polarity sensitive. Thank for any help!!
Will also post up some pictures of the unit in a few days.
