A bunch of stuff arrived for the car this weekend. A box of K&N fuel, oil filters, AEM intake filters and a bunch of AEM 3” tubing made its way to my doorstep. I can’t thank the people over at K&N enough for the opportunity to use their products on this specific car build.
I also spun over to empire fabrication in Simi this weekend to see if Sean, the owner, could school me on some fabrication. He was able to make something pretty rad from some sheet aluminum in a matter of a few minutes. Talk about talented.
Here he is measuring out the Mishimoto fans and the radiator and quickly gathering ideas to run with.
Here, after the break lines and overall dimensions were figured, he is shearing the material for those perfect lines.
Another sweet tool over at Empire is the Pulmax. This machine was used to shear perfect circles in the material for the fans to pull air from. They turned out awesome!
Here, the press break was used to create the 45* and 90* bends to fit the outsides of the Mishimoto radiator and hold the slim fans.
A bit of fitment verification goin down.
Lastly, here he is throwing down some dimes with his eastwood tig 200 to mount it onto the radiator. This I feel is a better design with all the vibration that is to bound happen than to bolt a shroud onto the radiator.
The end product turned out awesome and with a great amount of clearance.
I was also able to make a fuel pump hanger this weekend with the help of my buddy Clint. I used the stock hanger, -8 bulkhead fittings and some 5/8” straight tubing with a single flare on the end. The pump is a Bosch 040 submersible pump. I think she came out pretty nice.
