J30 WITH 2.50 CUSTOM EXHAUST SYSTEM
GerryO
Car: 1993 J30t
Pearl White
Black Interior
gr8scott72 wrote:
I know what it sounds like. It sounds like crap. I can't imagine how loud yours is if you just went straight pipe all the way back to that little muffler.
Six cylinders just don't sound as good as eight, and even the exhaust note of a 4-cylinder engine sounds better (Sesco Chevy, Offenhauser, VW, etc. and probably this one below too).
Chevrolet Unveils New Midget Racing EngineWritten by: SPEED Staff SPEEDtv.com 05/07/2008 - 12:45 PM Indianapolis, Ind.
The Chevy Midget racing engine's all-new design features an exhaust-side camshaft that allows for optimal airflow and repositioning of spark plugs and fuel injector nozzles.
The new methanol-burning 166ci (2.7-liter) Chevy Midget racing engine produces more than 350 horsepower. The lightweight, inline four-cylinder engine employs an aluminum block and cylinder head with two valves per cylinder. Per USAC rules, the Chevy Midget engine is equipped with mechanical fuel injection and utilizes an electronic ignition system.
Sixes are best kept quiet.
Modified by GerryO at 7:49 PM 10/30/2008
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Wow that's a lot but mainly because of the menthol injection. We can possibly get that much too if we add menthol injection.
gr8scott72
Car: 1994 Infiniti J30t
All matter of opinion I guess. I do prefer the sound of an inline 6 over a V6 (Sounds different because of the different firing order of an inline.) A couple of cars ago, I had a 95 VW GTI VR6 which is a narrow angle (15 degrees) 2.7L V6. (That has the same firing order that an inline 6 cylinder does) I had a Magnaflow exhaust on there and it sounded fantastic. It would even belch a small flame and POP, every time you reved 1st to redline and then shifted quickly into second.
J30inthe sun
Car: 1997 J30
Where can I get those resonators & muffs?
Resonator brand, muffler brand & part #s for both & where to buy PLEASE!
4-5 Bennies? Did that include parts & labor at a shop or did you install it yourself?
That doesn't sound so bad after all this in the last month:
TPS $50New rotors & pads, front & rear $300Timing belt kit $400 Plugs $50Tension rod bushings $70Fuel filter $10Front struts, boots, top strut mounts, front springs, trans filter with gasket $840All new tires & alignment $550
Timing belt kit, plugs, tension rod bushing & fuel filter labor $640Front strut parts replacement, trans service, brake fluid flush, rear differential fluid change & clean idle air control valve labor $700
Total $3610 on a car KKB values @ $6000 in mint condition retail. I think?
I am at 109,000 on my 97 J.
J30inthe sun
Car: 1997 J30
gr8scott72
J30inthe sun wrote:Where can I get those resonators & muffs?
Might be a little more than that as it is about $400 just for the parts. It would just depend on how well you know the muffler guy.
I used resonators like this (x4):
http://cgi.ebay.com/ebaymotors...89794
They say cats, but they are just straight thru resonator. I think those are the exact ones I used.
Mufflers like this (x2):
http://cgi.ebay.com/ebaymotors...46512
I would need to check to see if that's the size I used but I'm pretty sure it is.
and a couple of these tips:
http://cgi.ebay.com/ebaymotors...56021
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Your VW must have sounded hot and an occasional shot of flames would have only added to it. I just remember when six cylinder divisions started to form at some of the local short tracks and my first visit to the Laguna Seca road course, after years of hearing only V8s and 4 cylinder engines sans mufflers. And even now it's sad to hear a six cylinder Camaro with "headers" on the road. I miss the rumble of a V8 and at least the sound of the VG30DE is muffled to the point to where what you do hear sounds good. JIMHO.
I also recall some stating that the early stock 240Zs/L30 engines with their solid lifters and quiet exhaust sounded sort of like vacuum cleaners.
Later and thanks.
#1 Sailor Scout
Car: 2007 Honda Civic LX
Infiniti J30 fan
Dang...you used resonators that were designed for a Civic...pwnage!!
j30t_Dan
Car: 2009 Nissan Sentra SE-R
Bling Bling
well done sir. sound must be amazing.
#1 Sailor Scout
Infiniti J30 fan
j30t_Dan wrote:Bling Bling
For whose exhaust?
yodawill2000
Car: 94 Infiniti J30
You should have heard the 5 Liter V6 I have in my 63 GMC the day I removed the pipes from the exhaust manifolds LOL
Half the Town prolly thought the end was coming !!!
That thing ROARED.
#1 Sailor Scout
Infiniti J30 fan
yodawill2000 wrote:You should have heard the 5 Liter V6 I have in my 63 GMC the day I removed the pipes from the exhaust manifolds LOL
That thing ROARED.
A 5.0 V6?!?!?
I've never heard of one. I always thought that 5.0s were V8s. (Mustang GT)
yodawill2000
Nope
I gots one Here's a pic of one with the Plaid Valve covers like I have .It was the beginning of the GMC Scottsman.Has Huge pistons and tourqe out the wazzoo
http://www.phillipspremierauto...a.jpg
GerryO
Car: 1993 J30t
Pearl White
Black Interior
yodawill2000 wrote:Nope
Wow! My '54 F-150 had a 239 cu in V-8 (not a flathead), which I always thought was really small, but it works out to about 3.9L, eight tiny pistons and not a lot of torque.
Those valve covers are better/way F A S T E R than chrome!
Modified by GerryO at 6:38 PM 11/6/2008
yodawill2000
That's why I'm holding on to it ..My son and I are going to restore it to mint condition someday .Motor still purrs like a kitten.5500 Lb 4 wheel drive monster .. hehe Full sized bed too !!
#1 Sailor Scout
Infiniti J30 fan
yodawill2000 wrote:That's why I'm holding on to it ..My son and I are going to restore it to mint condition someday .Motor still purrs like a kitten.5500 Lb 4 wheel drive monster .. hehe Full sized bed too !!
YEEEEEEEEEEEEHAWWWWWWWWWWWWWW!!!!!!!!!!!!!!!
GIT 'ER DONE!!!!!!!
J30boy31
gr8scott72 wrote:
ppastos wrote:Whats it sound like too.
I know what it sounds like. It sounds like crap. If you cut out the cats and just put straight pipes in there you get a tinny, metal rattling sound plus with only having that one muffler (if you can really call it that) I bet it drones like nothing else. Probably have to take a can of advil with you for trips longer than 15 minutes.
And, why have true dual exhaust on a car and then stifle all those gasses down into one pipe right before the exit?
If you don't have any other resonators other than that rear fart can, your car is too loud and probably very blatty sounding under acceleration.
Here's mine:
front cats replaced with straight thru resonators:
straight thru oval magnaflows:
rear view:
Magnaflow tips:
And here's what all that AND another set of resonators added behind the magnaflow mufflers to help quiet it down a little more sounds like:
But why did you go with 2.5"? alot of people said thats too big for a n/a car plus considering the tubing from the header is like 2".
f33lmywrath
Car: 1993 J30
This thread is from 2008. None of the posters are active on this forum anymore. Unfortunately, this J30 sub-forum is pretty dead now a days :cry:
