J30 LSD question
ukrainekid
Car: S13 SR20det Red Top
Hey everyone, i just picked up a j30 lsd from the Junkyard. It came off a 93' so the output flanges have a diff bolt pattern. My question is can i simply use the out put flanges from my open diff and put it in the J30 diff and if so i am not exactly sure how to change the out put flanges.
Please is possible refer me to a thread with all the details. I found one a while back which was great but i never bookmarked it.
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
ukrainekid
Yeah i did find i can either use the output flanges or the 93' j30 axels. I also here people talking about needing a shorter driveshaft. I did a swap with my friend but we used a 95'.j30 diff and the drivde shaft wasnt a problem. Should i have a problem with the driveshaft on a 93'
costa_rican13
Car: 1993 s13 coupe
Just use the j30 axles. And the drivshaft will need to be and abs shaft. Also get solid diff bushings
ukrainekid
ok sounds good thanks, anything other suggestions please do
