R4v3n »
https://forums.nicoclub.com/r4v3n-u7996.html
Mon Sep 15, 2003 4:16 pm
I took my car to a dyno and it turned up 175 hp to the wheels. All I have done is JWT Intake, JWT ECU, and Unorthodox Racing Pulleys. My car NEEDS a tune-up though, and I'll be doing that soon, as well as flushing out the trans, rear-end, and fuel system. As far as the term cat-back goes, a cat-back exhaust means that you have pipes running from the catalyic converters to those 2 mufflers you got, what we are asking is if you have taken off the catalyic conerters (which apparently you did not), and ran piping from the manifold back. It says on the domain that you ran cat-back from the manifold back, but thats kind of a double negative. You either are running cats with new pipes out to the those mufflers you got, or you completely pulled the cats off and are running pipes from the exhaust manifold back to the mufflers. of course, you COULD run high-flow cats to get the best flow thats legal because you will automatically fail emissions without cats. The car should run though, but that I am not sure of.
