fxgo »
https://forums.nicoclub.com/fxgo-u3333.html
Tue Dec 03, 2002 1:43 pm
Thanks guys,
The J30 is a 1995. When I purchased the J30, I run the vin through the dealer. The timing chain was replaced at 33,000 miles. So, I don't have to replace the timing belt until 135,000. So, If I don't have to do a timing belt should I replace the water pump anyway. What about the suspension?
On motorvac, the gasoline system equipment is a 12-volt powered 2-line cleaning system which connects to the engine through vehicle specific adapters for all types of carbureted and fuel-injected engines. The equipment passes a detergent and gas mixture through the components of the fuel system. With the engine off, the system removes both organic and inorganic fuel deposits that build up in the fuel rail, injector screens, and pressure regulator areas while filtering the contaminants through the on-board filtering system. With the engine idling, the solution passes through the injectors or carburetor jets and into the engine’s combustion chambers. Carbon, gum and varnishes built up in these areas are softened and passed harmlessly out the exhaust, or are removed by the unit's on-board filter.
I did it at 68,000 miles. It work great for me.
Thanks for your help. You guys are great.
Regards,
Frank
