I could probably build a production jig for the drivetrain, but with as much free time I have to put into shop work, I will probably never have time to do side work other than my own. Lately I have been playing with wiring here and there when I do have the time. It's not something that is picture worthy
. So far I broke down the fuse box, simplified it, made my own panel to mount the fuses and relays, and mounted to the passenger air bag location. I removed the bolts from under the dash that keep the air bag door on so that it can simply be popped off the dash when access is needed. Think of it as a hidden and out of sight fuse box. As of now, I have been working on pulling out all the wires that I don't want and soldering the remainder back together. Most of it needed shortening. I finished the whole shortening part, but now I have to do the wires that feed back out front for the lights, washer fluid, horn, low brake fluid, ac compressor, ps pressure sensor, alt and lower harness. I tend to do wiring slowly, just so sure that I get it right lol. It's something that's a pain in the a** to diagnose if something is wrong, like a needle in a hay stack. After that's done, I have to move onto the engine harness. From there, it will probably be a test phase to see if everything works. Then it's on to the hydraulics and awd pump. I am basically at the tedious end of the build where it's a lot of nick nacks that need to get done.
