Ok here are the pics of today I promised.
Such a cold morning to start lugging this thing around the driveway.
I had just enough head room to get it into the bay. There was about 1/8 inch gap from hitting the garage door.
Here is a shot of the transmission starting it's way into the tunnel. It's longer than the engine bay!
I had to cut the adjustment handle off the harbor freight leveler due to interference with the chain
. It worked just fine with a cresent wrench after that
I had to shimmy, shake, huff, puff, grunt, snort, and roar to get it in that far. That's all she had due to the transfer case bumping into a mysterious hump in the transmission tunnel. Only 1.5 inches to go...
Here is the common area where the bell housing hits the transmission tunnel with RB swaps. I have seen this done two ways, grind off the webbing on the bell housing around the starter hump, or you can simply beat the transmission tunnel until it submits to your demands.
This is why I couldn't get it all the way in (that's what she said). There's a funky nonfunctional hump just behind the stock transmission bracket mounting point on the passenger side held on with just 6 spot welds.
Here's a view of the shifter hole while I was sitting in the car for a break. It looks like it will center up nicely when everything is scooted back that last 1.5 inches.
I channeled my anger from not being able to get the engine fully mounted. It was a Thor moment. Hopefully that is enough to clear the bell housing.
There is the bastard hump on the right that ruined my progress. I will have to grind off the 6 spot welds and hammer the area it is covering to clear the transfer case. To the left of it is the stock transmission mounting point. I will probably need to trim it down in case the front driveshaft doesn't agree with it. I am positive I can't mount the transmission using those points either, so off it goes. That's the plan for tomorrow - grind, chop, bang, and try again. It SHOULD be at home in the car by the end of this weekend.
