I bet the dealer didn't say when. Shame on your for believing him.Haitian_King wrote:My transmission fluid however was brown. Didn't smell burnt but judging by color, I think it needs to be replaced soon. When I bought the car, the dealer told me that all fluids had been replaced.... I take it it's time to change?
I would say you are about 40Kmiles over due, at least.
Bite the bullet, get the kit from Joe, get 14 qt. of Mobil standard ATF and 14 qts. of M1 ATF and 6 oz. of LubeGuard Red.
http://www.findashop.com
Dont' screw with the inefficient drain and refill multiple times. Bite the bullet and sind a shop that will flush it with teh standard fluid, drop the pan, clean it and the plug, change the filter and O ring, replace the gasket and the one time use bolts. Now mechanically exchange with the M1 ATF and top with 6 oz. of Lube Guard Red.
Your transmission is on life support, so you need ICU type care if you want any mileage at all out of it.
Next time, change it while it is still pink at 25K or when it is not bright pink (white paper towel test), whichever is first.
How about the auxiliary ATF cooler?
Any bets on the PS fluid?
