Its 10:00 pm, do you know where your oil strainer is?
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
I found out where mine was tonight.....
Floating at the bottom of my oil pan.
Where it used to be attached to the pickup tube.
The strainer opening.
The pickup tube, with the windage tray removed. My engine has been taking in oil through just this tube, I'm rather surprised its not knocking. Good thing I'm so anal about keeping my oil level perfect.
The broken S13 SR strainer next to the new S14 SR strainer, notice the differences.
I think Im going to do an article on this one, once I get the pan all cleaned up and ready to install.
MellowZ32
Car: Pornographer's car
good thing to found the problem soon!
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
I see that the new support is attached to body of pickup and not the oil feed tube. It looks like a "product improvement" to me. Maybe you got and older one????
IanS
MellowS13 wrote:good thing to found the problem soon!
I wouldn't say soon. I've been dealing with odd oil pressure issues for almost a year. I was experiencing dropouts in oil pressure during hight cornering and throttle situations. It would drop for just a second. I replaced every part of the oil monitoring system. Gauge, sender, tubing, even the entire oil filter housing. It was such a weird issue that I thought it was a false reading. Now it all makes sense.
gmac708 wrote:I see that the new support is attached to body of pickup and not the oil feed tube. It looks like a "product improvement" to me. Maybe you got and older one????
Thats one of the differences between the S13 and S14 SR pickup tubes. I have an S13 SR, but I chose to use the newer strainer because they redesigned it. The opening is also larger on the S14 unit.
The S14 strainer uses a different bolt hole on the girdle, but it bolts up with no modification to anything.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
Looks like a "must do" to me.
IanS
gmac708 wrote:Looks like a "must do" to me.
For $45 for the strainer and gasket from FRSport, I agree. Had I been aware of the problem, I would have dont this years ago.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
I wonder if pan ever got smashed up and then later replaced?!?!?Maybe it started a crack and cycle fatigue finished it off. No doubt that the S14 pickup is the answer.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Not the first time I've seen that happen. Next time I pull my pan, I'm replacing it with the updated part.
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
FlatBlackIan wrote:I found out where mine was tonight.....
If it was floating then it must have not been at the bottom of the pan.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Was the pan dented or anything?
I went to look at a g20 last night that the owner said nothing was wrong with it: The oil pan was smashed in like 2 inches! I could see the outline of the pickup. I told the seller about it and a oil leak. He didn't act too surprised and wouldn't come off the price. I didn't want it after that.
IanS
When I got the engine 5 years ago, the pan was a little dented, but I straightened her out. This time, she has a ding here and there, but nothing substantial.
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Good to see you caught the problem before it really kicked you in the A$$.That's what those little mechanic cameras are good for.On a side note. I can't look at your avatar with a strait face.
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
When i read things you post i imagine Richard talking.
Bumnah
Car: 1992 240SX, black. Bone stock.
Good luck getting that bolt in for the mounting bracket on the pickup. WHAT A PAIN!
I got in by using a flat head screw driver to keep it in place, and then getting it started with an open ended wrench. Hated every minute of it.
MastaYu
Car: 92 Nissan 240SX SE HB
I'm definately gonna get the updated pickup.
IanS
Bumnah wrote:Good luck getting that bolt in for the mounting bracket on the pickup. WHAT A PAIN!
You aren't kidding. I already had it installed when I posted this thread last night. The bolt was a b****andahalf. Not to mention, retard me still had the oil pan laying under there to catch residual drips, and I droped the bolt into it 3 times before sucking it up, and letting it drip on the floor.
