evlknvl »
https://forums.nicoclub.com/evlknvl-u81030.html
Mon Nov 12, 2007 7:37 pm
wasnt sure where to post as the itb setup on ka's thread is locked to replies. in the process of installing itb's to my ka and would appreciate some feed back regarding the ecu setup. from most posts i have seen so far most ppl use megasquirt/megasquirt II as their ecu unit. have a motec m4 pro ecu unit and would like to know if this would be easily adapted for the application ? think i seen a post somewhere stating megasquirt was the only way to go but i find that a bit hard to believe seeing the motec unit has alot more functions, can use most aftermarket parts(trigger wheels etc) with ease and is alot more expensive. easily keep my distributor with motec too. any advice would be appreciated.
