IT BEGINS! ka-t
turbo2nr
Car: 97 240sx (kouki)
well im finally gona do it, im starting my ka-t build after a yr of wating paciently and sourcing parts ill start pulling off the old exhasut mainfold tomorrow.
any tips or advice are appricated.
my plan of attack:remove stock header/downpipeinstall revhard + turbo+downpipe.tap into oil pan for returntap into pressure sending unit for feedremove bumpermount fmicmock up pipesweld up piping and re-route vacume hoses.remove stock injectors/railinstall top feed injectors + railinstall aeromotive fpr+ linesinstall fuel pump
i think i have it down more or less..
my only issues are what to do with the egr? block it off, or remove it? if i remove it do i have to pull the intake manifold off?
also i have msd 52lb injectors. what kind of o-rings do i need? can i use the ones that are on the injectors? and as for the install on the fuel rail do i just "snap them" into the fuel rail. they still fell a little loose. any tips?
also how can i test them to see if they are hi/lo impedence.
all and any tips and advice will help.
This will be a long ongoing thread with pics. soon as i start. im sure ill run into alot of problems but hopefully ill make it.
thanks in advance
KATwo40
Car: 1993 240sx KA-T
With what will you control the larger injectors and Z32 MAF?
turbo2nr
for now just the safc.. im looking into haltec or a tuned ecu. i want to get a tuned ecu, but right now the car is still an auto i dont have all the parts to conver to 5sp yet. so i was going to wait and get a tuned 5sp ecu obd1 with a step down harness.
but if all goes well and i get enough support i might mess with the haltec instead.
for now im just gona tune with the safc+wideband for 8psi ( thats the spring i have in my wastegate) and pull timing back about 2-3 degrees.
KATwo40
Pull back about 4* for that boost pressure on the T04b.
Should work out just fine for ya!
Florida240sx
Auto ecu's work on manuals.. Don't think there has ever been a tuning issue to my knowledge...Spray all your exhaust bolts with PB blaster like crazy
pr240sx
Work in stages.Electronicsfuel oil turboexhaust (downpipe)clean air (intercooler piping)
Work cleanly and with patience. This is a no rush job.
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
keep us updated, very interesting!
rotorimp
Car: 02 Xterra, 60 IH Metro
Take the pan off to tap the oil return-you do not want any metal to get into the motor.
turbo2nr
thanks for the support guys, i cant wait to go home and start.
i got a crappy FMIC 26x6x3 square end tanks.
i was think about a e-gay intercooler. 28x9x3? to big?
i plan to work in stages, i think that is the best way, i got untill summer to finish so im in no rush. im going to take my time and do everything right and neatly.
should have some first pic up by tomorrow, possibly tonight if im not to tired..
KATwo40
Either size intercooler will work. The Ebay intercoolers seem to have better flow transition on the end tanks. You might want to take a hard look at them.
S13FX
Car: '69 l20b Dimeski :)
Hey I use an Auto chiped ecu on my ride and have no problems at all.
racin-type
Car: cars
Yo i didn't know you were starting starting. thought you just wanted to mock up the pipes and put the car back together. didn't know you had til summer. didn't ask him yet but I'm pretty sure Joe can weld the pipes in a 2-3 weeks time.
well holla at me if you need any help later
turbo2nr
thanks alot lo ill let you know when im ready to mock up the fmic pipes you can come over and help.
not much progress yet, basically took off the the head shield and 02 sensor. i sprayed all the bolts down with PB blaster.
the header bolts looks to be in very good condition. but the downpipe bolts looks really rusted. they will probably snap.. o well who cares as long as it comes off.
hopefull pic tonight if everything goes smooth..
nissanfanatic
Car: 1992 Nissan 240sx SE
Ebay intercoolers are where its at man...
Good luck! BTW, you can have the oil pan off, tapped, and back on in like 4 hours without pulling the engine.. I wasted my time on that **** the first time..
WDRacing
I agree, you don't even need it welded if you use bulk head fittings. I want pics posted soon!!!!
turbo2nr
UPDATE:
ive been so busy with work and work i didnt progress much. but after much soaking with PB Blaster and penetraion oil i got the exhasut maniold blots and downpipe blots loose with out any snapping. a breaker bar is the best thing ever taught of. on sunday ill hopefull have pic of the turbo/manifold.downpipe test fitted! yay! i cant wait.. makes me wana call out of work tomorrow.. but i need the damm $...
after the turbo is mounted the its off to tackle the oil pan.
any one got tips on how to car the highest up possilbe on jackstands? or any suggestion on how to get it higher?
thanks
WDRacing
My jackstands are huge...I can bring the beer cooler and everything under my car.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Yay! Post pics of this project! KA-T's make me happy.
turbo2nr
downpipe is off!
last pic of my stock motor yay!
good pic of turbo mounted tomorrow!
turbo2nr
PICS! turbo downpipe/ manifold/wastegate on!
Modified by turbo2nr at 12:46 PM 1/7/2007
WDRacing
Looking good so far man. Make sure you wrap the MBC or it will melt. A crude barrier can be made from sheet metal and some heat wrap. I'd wrap the entire DP while I was at it as well.
WD
turbo2nr
update!oil pan is a p.i.t.a. to remove.. finally done... special thanks to brewster240sx for the help when you came to pick up the rims.:D
should be back on by thursday..dam work...
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
btw way i hate usps! where the fu*k are my fmic pipes?
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
looking good man,
for your egr just buy the block off plate on ebay, or weld it shut. takes about 15-20 minutes to install. if you have small hands even faster.
like others have said, design some sort of heat-shield. I used header heat shielding from a Prelude H23 motor. i went to the junkyard and pulled some shielding from a 300zx, will work great and with some minor drilling, it will fit in and look like Oem.
boznuttz
Car: MS13
Looks great so far, especially on the oil pan. How is clearance with the ac compressor? And no hard feeling on suspension, eh? I think I may keep the Konis after all, lol.
turbo2nr
yup heat sheild is a must, im actuall gona wrap the downpipe as well.. but im gona make one to for added protection.
boznuttz yea no hard feelings i didnt mean to come across as a d*ck just trying you help you sell. the clearnce for the ac brack is great its right after it. btw i know some one that might be getting rid of his stock t25 in nyc in about a month. if your intrested let me know.
boznuttz
Car: MS13
I sure would if it's in good condition. Lol, I should have more cash by then too.
turbo2nr
ALMOST THEIR I CAN TASTE IT!
sorry for the crappy cell fone pics, the digi cam battery craped out on me..
the fmic is just test fitted i still need to add all the couplers and im still wating for my 90 degree coupler to come so i can connect the turbo and the hot pipe.
i need to make a 3" pipe for the maf-turbo,finish the oil feedslot and drill out the manifoldand tighten everything upand fab the rest of the downpipe, and cap the egr
then on to the hard stuff the fuel and tuning , im hoping to turn her over next weekend, be sure to look for a vid!
i know im such ricer..
WDRacing
Anyone who does their own work is not a ricer in my book. Now if you put some faggoty *** wing on the back and decals everywhere, I might retract that statement.
Looks really good so far man. I love the Kouki...
babowc
Car: 240sx
dang that oilpan got tapped good.i wish i had that kinda welding skills, haha.
lookin good!
turbo2nr
thanks i just got the oil line on today,
question any quick wat to cap the egr? or just take it off and block it? i want to take it off but thier is one bolt thats a bi*ch to get too inbetween the 3rd and 4th runner its like impossible to get to it... it fustrates me..
thanks
