chanklas »
https://forums.nicoclub.com/chanklas-u143239.html
Mon Jan 30, 2012 7:27 pm
I have this issue with my dual cam, the issue is when i start the car it runs and idles fine. But when i take it for a drive the engine wont rev past 3500rpms. if i give the engine full throttle it makes this gargling sound from the intake. Sometimes it will rev high but it looses all torque and makes the gargling sound as well. I have replaced the MAF sensor, Knock Sensor, TPS Sensor, 02 sensor, The Coil, Spark plugs, Ignition switch. I have a walbro in the car and did a hot wire so it gives the fuel pump more power and flows more fuel. Im at the point where im going to do an sr20 swap. Ive thrown to much money trying to figure out why this dual cam wont run right. Since i have this issue. if i move to an sr20 swap will the same problem accure? I could use some help please
