85-720-z24 »
https://forums.nicoclub.com/85-720-z24-u204008.html
Mon May 14, 2012 11:19 am
I would look into checking all the small things before you go and tie up a lot of money and tme into replacing other stuff...
small things that are often overlooked: wiring harness connectors not fully push in together, lose wires, vacum lines could also have an affect... it can not run correctly due that it can not sense the corrct pressures created by the motor and will throw off more than u would think.... I have been bite in the A$$ a many of a time due to the fact that they are just cracked, not broken, but just cracked enough to leak vacum...
