wherearemypants »
https://forums.nicoclub.com/wherearemypants-u53902.html
Mon Jan 22, 2007 8:06 am
here's the deal... motor for motor swap for swap... is the work the same??? is one easier than the other... what about the aftermarket??? i understand that the sr is seriously backd by aftermarket parts... here's what it is
SR20DET Red Top... btw, what is the diff in the black top??? i found that too...$1,895.00 Motors average 35,000 miles and come with a 100% start up warranty.Engine Package Comes With:•Complete Motor•Throttle Body•Transmission 5Spd RWD (with Clutch Assembled to the engine)•Wiring Harness•All required Cables•ECU•Exhaust Manifold•Alternator•Starter•Power Steering Pump•Power Steering High pressure Line•Wastegate solenoid Controller•Wastegate actuator•A/C•Fuel Rail•Injectors•Canistor•Turbo•For Ignitor Chip, Master Air Flow (MAF), Air Cooler, Pipping Please add $595.00 to the total and call for availability. $1,395.00ca18det Motor with the turbo Transmission (5sp) Wiring Harness Cables ECU Cam angle sensor (CAS) Complete Intake Manifold Alternator A/C Power Steering Pump Brackets and Sensors
what else will i need for a ca18swap... with free shipping these prices are pretty good too right???... all help appreciated... i posted nearly the same on the sr forum too with a little diff imput... u guys are awesome thx for the help...
---wherearemypants---
