triple r wrote:if they are stock injectors..........yes. that nozzle keeps it from fouling the plug out under load. how did the car even run like that? i had this same problem. it would idle and when i got on it hard or at high rpm's, it would foul out those cylinders that had the bad nozzles......you will have to get new injectors
Yes, they are the stock injectors. So this would explain why I could smell fuel in cylinders 2,3,4.I hope they aren't too expensive from an auto parts store or nissan dealer.
Also, when i looked at my cams, the orange marked one (exhaust if i recall) was on the intake manifold side, and the green marked one (intake) is on the exhaust manifold side. Is that normal or what the hell is going on?
