pgt892 »
https://forums.nicoclub.com/pgt892-u2513.html
Thu Jun 02, 2005 11:52 am
Generally, no, there is no truth at all that SRs break down more than anything else. It's just like any other motor, if you treat it good it will treat you good. However, you are buying a motor that may have been abused, mistreated, or not used for a long period of time. If you don't do any prep work to the motor when you get it, then you might have problems with it. At the very least I would change all of the gaskets and the plugs, change the oil etc.. If you have more time and money I would bust it open and look at the internals, change the head gasket to a metal quality gasket. Point is, you don't know how the engine was used/abused in Japan so you don't really know what you are getting until you work with the motor. But after you do the work to it, the motor will treat you right.
