InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Fri May 21, 2004 12:13 pm
Quote »actually you are incorrect.. its not the manifold that matters, its your valvetrain.. when (turbo app) you build boost, it holds a pressure in your intake manifold.. lets say you boost 10psi.. that means in your intake manifold/charge piping, there is 10psi stuffed in there.. its up to your valve train to be able to suck it all in..[/quote]That's not correct actually. If it was, then changing the intake manifold wouldn't have helped his car breathe higher on the top end (the turbo SR graph that was posted). There's generally pressurized air in the plenum, but the air in the runners is almost always bouncing back and forth, and not at a constant pressure, so when your valves open, the air has to travel up the runners, unless you're at an RPM that catches the reversion wave correctly. An engine that makes 140 torque is burning X amount of fuel and air. If the same engine makes less than 140 torque somewhere else in the powerband, then you're burning less than X fuel and air. It can be due to the cams, but when we're talking about an engine with 264 degree cams dying off at 5000 rpms, there's a pretty good chance that's not the problem.
Quote »TORQUE ----------------------- HPLONG RUNNERS --------Short runners[/quote]Not quite correct. Long runners make more torque, due to the incoming air being able to build more velocity and create a forced induction effect, but cannot breathe properly at higher RPMs, so the shorter runner manifold makes less torque at low RPMs (though not all that much), but maintains that torque number much better through high rpms, and thusly makes more torque and more power at high rpms. If you have an engine that has long runners and breathes properly already, then shortening the runners isn't going to help. However, that's not the case with the KA, as it does not breathe properly above 4200 rpms or so, when the torque starts to fall.
Quote » look at hondas.. they have what.. 3" runners..[/quote]not all of them, but the higher revving ones do. Quote »while our nissans have runners anywhere from 12" - 18" long... im willing to bet if someone made a long runner manifold for there honda, it would gain torque..[/quote]Yes, it would gain low-end torque, but if it was something high-revving like a type-R, or an s2000, then you would lose high end horsepower, because your torque would start to die much earlier.
Quote »now for an NA application, drag race/auto-x etc etc.. short runner's would be the choice of the hardcore guys, because you are usually hanging around 4-5k anyways.. so you wont "actually" need torque. but for daily drivers, and turbo guys.. our long runners would be just fine..[/quote]No, see, this is what you're not getting. It's not like you're going to have half your normal torque if you have shorter runners and just magically gain hp. You still have low-end torque, just not as much. You breathe better at the high-end, so you make more torque on the high end, which translates to more power.
