Is my turbo blown or worse?
Edub1
Car: 89 240sx KA-T
How do you get the second nut loose?
Chezedik
Car: 1991 Nissan 240sx
What second nut? I didn't, I assumed it was part of the shaft, since the wheel and shaft sell as one piece from Garrett. But I didn't take it apart, didn't need to. Just set it in the dip.
Edub1
Car: 89 240sx KA-T
Nut on compressor, nut on turbine. Which one comes off first? How do you remove the other?
Chezedik
The one on the compressor comes of, not on the turbine. It looks to be one piece. I just put a 9/16" (14mm) on the tubine side nut, on the compressor I used a 12 point 1/2" socket (12.7 - so avoid using 13 if you can help it). I torqued it back down to about 10 ft/lbs.
Edub1
Car: 89 240sx KA-T
So how do you get the compressor wheel off?
Chezedik
I covered that. You use a wrench to keep the turbine wheel stationary, and a rachet on the compressor. When you turn them the opposite way, one will loosen. Be sure that you are turning the compressor to loosen it. You know, I could sell you my T3 .60 cover, and you could turn your T3/T4 back to a T3, and sell it on ebay, or I would be willing to trade compressors. But you will want to rebalance my T3. If you like, you can ship it to me, and I will rebuild it. Also, if you pay to have it done, I will balance the assembly (I will not personally do it, but I will take it somewhere, and will not charge any sort of fee.)
