Is it the Starter , Alternator, battery or fuel related - long Crank to Start Car in Morning
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
tooth knockn
Car: 2009 ex35
Dzionassi wrote:
Sat Jul 03, 2021 2:28 pm
BG44K. MMO is for kids, but is it better than seafom
Hi I just got the bg44k, should I mix w/ full tank of gas or half?….
My own mechanic didn’t want to change the starter . ..
He said it also be the Camshaft sensors or crank shaft sensor
tooth knockn
Car: 2009 ex35
He said wait for check engine light….
This is annoying…
I just want to prevent getting stuck…sigh
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
tooth knockn wrote:
Thu Jul 08, 2021 10:04 am
+1. Crank more likely than cam.
tooth knockn wrote:
Thu Jul 08, 2021 10:09 am
-1. There's an easy test to distinguish CKP from CMP on most Nissans, which is put a streaming scanner on it while it's acting up and see if it shows steady RPM while cranking. The ECM gets its RPM data exclusively from the crank, so if the RPM reads 0 or jumps around while cranking, the CKP is the culprit. If it reads steady and normal, then a CMP is responsible.
tooth knockn
Car: 2009 ex35
VStar650CL wrote:
Thu Jul 08, 2021 10:32 am
Hi ok I’ll try that, I have a Bluetooth obd ii scanner with certain filters…
But what is ckp and cmp? K for crank? M for Cam?
VStar650CL
Technical Expert
tooth knockn wrote:
Fri Jul 09, 2021 8:32 am
Yep, standard industry lingo. CranK Position, CaM Position.
tooth knockn
Car: 2009 ex35
UPDATE: I did not change Starter. . . . I did use the recommended gas injector can from Amazon .. . SO far working good ... . Starter working fine. . . thank you all !
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
