You think I could replace it myself?VStar650CL wrote: ↑Tue Jun 29, 2021 10:51 amTry a new crank sensor. When they start to go south they often produce spotty output at cranking speed when cold, then "wake up" with the higher reluctor-wheel speed once the engine catches and runs. Because they're fine after the engine spins, it usually doesn't cause any DTC's. Cam sensors can cause the same behavior, but it's less frequent and more likely to cause a DTC.
tooth knockn wrote: ↑Tue Jun 29, 2021 9:41 amHi so I have a 2009 ex35 , now has 141,000 miles
Battery is new, purchased around winter of 2020, red top by Optima
Air filters have less than 5000miles
Oil changed every 4kmiles
For like the last 3-4 months car has been taking longer to start in the mornings.
Went to autozone, battery checked good.
No problem when car starts, drives good.
I’m thinking it’s the starter, but my mechanic says it could be the battery….
Anyone with experience with this situation ?
The battery is less than a year old. It was tested today with one of those devices from the parts store.. 12.79voltsVStar650CL wrote: ↑Tue Jun 29, 2021 2:18 pmUnless you're hearing the starter run noticeably slower when cold, I doubt that's the issue. Even if you do, chances are it's the battery causing it. Weak starters almost always misbehave worse when hot. Batteries are the opposite.
Didn't say I thought your battery was bad. Just that cold misbehavior is uncharacteristic for a starter, so I fear you're barking up the wrong tree.tooth knockn wrote: ↑Tue Jun 29, 2021 2:38 pmThe battery is less than a year old. It was tested today with one of those devices from the parts store.. 12.79volts
Last week I also tested the battery at another car parts store, same, battery was good.
VStar650CL wrote: ↑Tue Jun 29, 2021 3:26 pmDidn't say I thought your battery was bad. Just that cold misbehavior is uncharacteristic for a starter, so I fear you're barking up the wrong tree.tooth knockn wrote: ↑Tue Jun 29, 2021 2:38 pmThe battery is less than a year old. It was tested today with one of those devices from the parts store.. 12.79volts
Sure, check voltage drop while cranking if you can get an assistant to turn the key. Healthy batteries won't go much below 9V while cranking, very healthy ones will usually bottom out around 9.5~10.5V. If you see a drop in that range then it isn't the battery, starter or cables causing your issue.tooth knockn wrote: ↑Tue Jun 29, 2021 4:35 pmTomorrow I will take a reading of the battery before I start it up. Just in case.
+1. Sniff the tailpipe to check that, with the help of an assistant. If you have a leaker, you'll get a white puff with an acrid, chemical smell right after the car starts.
Haha, sorry, but you have some fake information. Who told you that? Car can be even started if voltage drops lower than 12v.tooth knockn wrote: ↑Wed Jun 30, 2021 7:10 pmThe battery is about 6 months old… it should be 12.6+ v before a start up ….
Not fake info but just what the guy told me at the parts store and I also checked onlineDzionassi wrote: ↑Wed Jun 30, 2021 8:23 pmHaha, sorry, but you have some fake information. Who told you that? Car can be even started if voltage drops lower than 12v.tooth knockn wrote: ↑Wed Jun 30, 2021 7:10 pm
I made this picture specially for you. Parked my car 2 hours ago and i can guarantee you, it will start without the problem tomorrow morning.![]()
I am going to repeat my self, if it is cranking, but not starting right away, it is most likely fuel pressure problem. Especially, if this problem occurs after car was parked for couple hours.
Good luck.
Interesting lay out you got in your car…. What is all the?Dzionassi wrote: ↑Wed Jun 30, 2021 8:23 pmHaha, sorry, but you have some fake information. Who told you that? Car can be even started if voltage drops lower than 12v.tooth knockn wrote: ↑Wed Jun 30, 2021 7:10 pm
Good luck.
All kind performance modstooth knockn wrote: ↑Thu Jul 01, 2021 1:03 amInteresting lay out you got in your car…. What is all the?Dzionassi wrote: ↑Wed Jun 30, 2021 8:23 pm
Good luck.
Do you like using that metal bar?Dzionassi wrote: ↑Thu Jul 01, 2021 11:47 amAll kind performance modstooth knockn wrote: ↑Thu Jul 01, 2021 1:03 am
You are wasting money. Just stop...tooth knockn wrote: ↑Sat Jul 03, 2021 8:41 amSo I think it wasn’t the battery… but I’m still going to change the starter… since I drive a lot between 2 states
HmmmmmDzionassi wrote: ↑Sat Jul 03, 2021 9:01 amYou are wasting money. Just stop...tooth knockn wrote: ↑Sat Jul 03, 2021 8:41 amSo I think it wasn’t the battery… but I’m still going to change the starter… since I drive a lot between 2 states
My suggestion at this point is to buy a can off bg 44k Platinum. Run it in full tank.
This is cheapest attempt to fix your issue.
